T1700X mower problem
cwpbsp
t1700x
May 20, 2012
Alvaton, KY USA
Have had a Kubota T1700X with a RG44LT-17 mower for several years now. Lately, with sharp blades, one outside blade does not appear to cut as well as the other two. Could the belt be slipping on that pulley or do I have an even more serious problem.
Thanks
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Look deck belt, if the belt's been slipping it'll have scars. While you're in there slip the belt off and give that blade a spin and see if it's stiff. Another possibility, though I don't know if it's possible on that deck, is the blade is on upside down. I've seen it happen.
3,986
One other thing you might want to look at is,,,,,,the blade bolt TIGHT??? Dont ask
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Should just be one continuous belt around all the spindles, so if one goes they all go. Could be an issue where that one blade struck an object and it knocked the spindle out of alignment. Check to see if there any side to side play. Or see if you need a shot of grease on the spindles.
hodge
Nov 19, 2010
2,946
511
Love, VA
Check the spindle pulley for grease- perhaps a previous shot of grease got some in the pulley groove. You should also check the spindle itself- bearings may be seizing up, causing the blade to spin slower.
