T1600H / z482 oil overflowing from breather?
PenderBen
B6200d, Bobcat 323j, T1600
Aug 31, 2012
60
Gulf Islands, BC Canada
Hello everyone.
I’m having a strange problem with the engine in my T1600H, which I believe is a z482.
I have found a few posts here and elsewhere on the internet of people having the same problem with the same engine and other Kubota engines, but never any solutions or follow up.
I have not had it too long, bought last year but only started using this season.
Before I purchased the mower the engine had been rebuilt (bored, with oversized pistons), new gaskets, etc- I don’t have any real documentation, just receipts for the parts, the previous owner is a professional diesel mechanic, but not local so I can’t get him to look at it.
It starts easily, runs well, no smoke, plenty of power, doesn’t overheat, doesn’t use/lose coolant.
After running not very long and operating speed (5-10min maybe) it will suddenly spew a lot of oil out of the breather pipe, about a 1/3-1/2 litre, then it will stop loosing oil and continue to run normally, except that if I open the valve cover it is full of oil still, just no longer overflowing.
After this happens if I shut it down, the oil immediately leaves the valve cover and drains down as it should.
It’s about a 2.5l capacity system so there should be 1.5 +/- litres still in there, after it overflows it doesn’t register on the dipstick.
I have mowed with it a few time (I know that could be bad...), but it ran great, no overheating, no loss of power, didn’t run out of oil, just lost the 1/2ish litre once after starting out (I have the breather going to a catch can)
I have done an oil and filter change, checked and adjusted the valves, checked the breather filter (it was very clean), removed the push rods and checked all the passeges for obstructions, poured oil in each passage quickly to see if any of them drained slowly (they didn’t).
When I pull the dipstick while running oil spurts out, but not much different than my B6200 does, and the dipstick itself doesn’t ever pop out on its own, so there can’t be that much pressure built up in there.
I have run it with the valve cover removed, and it quickly fills the push rod passeges with oil after running for a bit at partial throttle, if I drop it to idle it drops down and doesn’t overflow, if I rev it up it will quickly rise again.
I haven’t done a compression test yet, (I have a compression tester, but none of the fittings are right for this engine, which I found out after removing the injectors), but I thought if the rings were bad or it was compression related it would be hard to start, and it starts easily hot or cold.
One suspicious thing I did find was foil from an oil jug in the valve cover, maybe something else could be in there blocking a deeper passage?
The guy I bought it from said he thought the ‘rings hadn’t seated yet’ and I should continue to use it, varying the speed and load, and to use oil additive due to ‘low ash content’ in modern oil- I don’t know anything about that.
There is no hour meter, but I estimate I’ve run it less than 10hours, and I don’t believe it was used much after the rebuild before I got it.
Does anyone have experience with something like that, or any advice as to what I can try?
Thanks
Ben
PenderBen
Aug 31, 2012
60
Bumping this, still looking for help.
I have now found what appears to be oil in the coolant, but no (apparent) coolant in the oil. I sucked some coolant out of the radiator and let it settle in a clear vessel for a day, and it was about 2/3 sludgy black (on top), 1/3 nice green coolant (on the bottom).
I***8217;m thinking head gasket.
I have limited diagnostic tools, and it***8217;s not easy for me to get any at the moment, what would be the best tool (if I can get any) to diagnose this, compression tester, or cooling system pressure tester?
Any advice is appreciated.
Thanks
rentthis
1,010
25
summerville,sc
From what you describe, I would agree with a bad head gasket. Oil in the coolant is an excellent indication. It probably wouldn't help but you might start by checking torque on the head bolts. A head gasket isn't really expensive and not to hard to do. After all the time you have had this problem it would be a good starting point.
PenderBen
Aug 31, 2012
60
Thanks for the feedback, I have ordered a head gasket, in the mean time I will try re-torquing the head bolts.
8,756
Harbor freight or similar for a compression tester.
If you have an auto parts store that rents tools you should be able to rent a coolant system pressure tester.
If you do a coolant system pressure test, do not crank the engine with the starter after the test, turn the engine by hand several turns to make sure you haven't flooded a cylinder with coolant.
PenderBen
Aug 31, 2012
60
I have a harbor freight compression tester, but none of the adapters fit this engine.
My main lack of available tools is that I’m on a small island, and most places on the big island are closed because of covid.
I’ll see if anyone local has a coolant system tester, that is a possibility.
