SVL-950-2 Front Door Hard to Close
Mikestolarik
SVL95-2s
Feb 14, 2022
99
14
Florence, Alabama
I have a Kubota SVL-95-2 skidsteerr.
Then the front door is open, front door has always been extremely hard to get the latch to "release". Once the latch releases the door slides very easy. The latches open all the way. The thumb levers are very easy to push. After pushing the thumb levers, I have to bounce the door 3-5 time before is begins to close. I have lubricated and cleaned every area. I have adjusted every: catch, lever, spacer, latch pin, bearing follower, alignment rubbers guides, cable and rod that I can find. What am I missing? Thanks in advanced.
5,124
Have you adjusted it per the WSM or just your observations of it?
whitetiger
Nov 20, 2011
2,593
1,105
Kansas City, KS
Typically, that is cured by backing out the 2 tapered rubber bumpers that stick straight down from the roof.
