Surprise find!
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
633
82
Rising Sun, MD
While doing some maintenance on the B2410 I found something.:D I was dressing up the bundled wiring behind the right tail light I found a #10 hot wire and a #10 ground terminated with a ring terminal. This is hot when the ignition is turned. I am going to put a switch in line and run a sprayer... :rolleyes:
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
You should trace it back to find out how much current the fuse that is attached to that run is....
Awesome find though, little things like that make life easier!
Butch
Sep 10, 2009
633
82
Rising Sun, MD
It is sweet! It traces back to all #10 wire and it is on a 20 amp fuse. It could take a 30, however I will play it uber safe and stick with the 20....
Butch
Sep 10, 2009
633
82
Rising Sun, MD
I looked in the work shop manual at the electrical wiring schematics... low and behold... it is a blind circuit for a add on work light.:eek: It is on all B2410 tractors. It is #2 in the fuse box. Hot only when ignition is on.;)
