Suitcase weights and Front end loaders
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
I'm curious to know what kind of load you are lifting on the rear that can't be countered by something in the FEL bucket. Why would you need suitcase weights?
ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
May 10, 2013
143
Suffield, CT
If the front end loader doesn't give you enough weight on the front end, you could always scoop up a bucket of soil to carry around.
Catchad81
Notasulga, AL
I'm guessing here...but he may be saying with the FEL off, it would be good to keep weight on the front, such as in the suitcase weights.
hdhedges
B2650 HST fel land pride BOX BLADE
Sep 1, 2014
15
Fort Davis, Texas
Pulling the box blade full of gravel up a long steep driveway my front tires tend to slip even with bucket full. If I drop into low and slow way down, traction is much better. Maybe more weight is not the solution? I find I have to raise the blade to dump some weight but then my surface finish is compromised. Back to the drawing board.
11,180
What your trying to do requires a lot more tractor than the B series, I can do it with my L but it's still a real workout trying to drag material uphill, especially if it's steep.:eek:
Drag downhill then at the bottom where it builds up scoop it up with the loader and drag that down. ;)
