The slide inside the injector pump is frozen. Will not move with soleniod removed. Can the side plate with the throttle lever and shut down lever be removed to free up the rack?
It might be moved by pulling the side cover, but your going to need to pull the pump out and have it rebuilt to free the movement up.The slide inside the injector pump is frozen. Will not move with soleniod removed. Can the side plate with the throttle lever and shut down lever be removed to free up the rack?
You can try, but I've never had much luck with that kind of a quick fix.Thanks, I had heard from another source that after pulling the side plate that WD40 would free up a minor problem with the slide without excessive force. Any thoughts on that?
Replying to 7 year old dead threads is a BIG red flag.When pulling the ip with a frozen rack pull the bottom 2 studs out and it will come right out then u can work on getting the rack un stuck hope this helps
He might not, but I do...Replying to 7 year old dead threads is a BIG red flag.
It a spammers M.O.
And your information is wrong btw.
Wanna know why?
