STRANGE L SERIES transmission, 8 SPEED PTO I THINK ANYONE SEEN ONE LIKE THIS....IT CAME IN ON HAVE TAKEN PART L2000, WITH NO ENGINE...IT HAS NO TAG ON THE SIDE ALL
![](https://imagizer.imageshack.com/img922/9793/YqVlNp.jpg)
![](https://imagizer.imageshack.com/img922/9146/oP1SId.jpg)
![](https://imagizer.imageshack.com/img923/5284/lEnm6L.jpg)
![](https://imagizer.imageshack.com/img924/3097/6TzhBo.jpg)
That looks identical to the transmission on my ex L1501. That's got the creeper lever with the gear shift and pto shifter.Transmission more than likely will be 8 forward 2 reverse.
Looks like that model only had one PTO speed.
So 16 forward, 3 reverse when coupled with the high/ low lever to the left of the seat. It won't allow you to shift into reverse when both levers were in low range.granted if you did manage to get the tractor in reverse with both shifters in low range, it would probably take you 10 minutes to back up 3 ft![]()
Good to hear. The left shifting lever will be for the PTO. And it's just a 4 speed pto.YEP THATS IT... I GOING TO MOUNT TO MY L175.... I GOT THE HOOD ALSO ON MY L175, L3901 WHEELS... I THINK THE TRACTOR WAS A ZEN NOH L1501
