Steering Wheel
BuckeyeStateOfMind
B2601 with LA435 loader, 60" QA bucket, and 60" Land pride box blade
Jul 15, 2020
21
Columbus, Ohio
Hey everyone, curious question. Does your tractor drive straight with the steering wheel in perfect centered position?
I seem to need the wheel to be upside down for the tractor to drive straight. Should I care about this?
SidecarFlip
Banned
562
Perfectly normal with hydrostatic power steering. There is no mechanical linkage between the wheels and the steering assembly so the steering wheel can be anywhere and usually is every time you shut it down.
BigG
Sep 14, 2018
1,953
774
West Central,FL
The steering is done with hydraulics not done mechanically. The steering wheel will not remain centered, it will vary. Sit on the tractor and turn the wheel and it will hit the stops on the axle but the steering wheel will keep moving. This normal for a hydraulic steer machine.
SidecarFlip
Banned
562
The steering is done with hydraulics not done mechanically. The steering wheel will not remain centered, it will vary. Sit on the tractor and turn the wheel and it will hit the stops on the axle but the steering wheel will keep moving. This normal for a hydrostatic steer machine.
Fixed it for you. Kubota's have hydrostatic steering. Cars with power assist steering are hydraulic, least the older ones are. New ones aren't.
3,314
Asking because I do not know.
I would have guessed the tractor steering would be called hydraulic, rather than hydrostatic. What makes the operation of the steering cylinder different than any other cylinder, so that it would be called hydrostatic rather than hydraulic steering?
Not disputing this, just curious...
Edit: I suppose it could be because of the way the control valve connected to the steering wheel works?
SidecarFlip
Banned
562
The steering operates with an orbital pump to direct the flow, much like a hydrostatic transmission in the Kubota's, just much smaller. Why the steering wheel never returns to the spot it was when you shut the engine off.
Been playing with your Mini-Ex at all?
OrangeKrush
Nov 15, 2020
1,044
517
Indy
So when I put my new steering knob on I’m going to position it lower left bottom. Is there a way to keep the steering wheel in this position while straight?
9,805
Nope... it won't stay put ever, It's going to travel all over the place.
You can force it back into position by bottoming out the cylinder and turning the wheel, but that's hard on the system and damage something if done repeatedly.
BA76
MX5400 Tractor, RB3784 Rear Blade, RCF2072 Brush Mower, FDR1672 Finish Mower
Dec 21, 2020
85
106
Illinois
That explains my recent dilemma. I put a steering knob on my MX5400 the day I bought it and have had to move it three times! Lol! I thought I was loosing my mind.
smittydog27
L3901DT, MX5200DT, Case 450, 1450 dozers, Case 530 const. king backhoe/loader
Dec 11, 2018
22
Huntington
So, on my MX5200, the steering does as you stated (it is in a different place every time I use it), but on my L3901, I have my suicide knob is at the 6 o’clock position every time.
Just my observations from mowing my 24 acre field. I had a lot of time on my hands to discover this. LOL
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Thanks Wolfman.. I kind of figured what the answer would be after reading previous post above but was hoping not!
Mak65
L2501 HST
Apr 25, 2019
136
112
TX
I have a L2501. I know the steering wheel location can “float”. Like smittydog27, my suicide knob is almost always at or near the 7o’clock position - where I placed it
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
The basic L series tractors have a steering gear not the hydraulic steering that is on most (all?) other Kubotas.
9,805
That's because your l3901 is not hydrostatic steering, it's power steering on a mechanical steering system. ;)
9,805
Again because you have a mechanical steering system on the l2501, not a hydrostatic steering.
BA76
Dec 21, 2020
85
106
Illinois
Well, I learned something about my steering.
Thanks all!
Me too! That’s what we these forums are all about. 🧐
5,450
I suppose the hydrostatic steering also explains why there doesn’t appear to be any “feedback” from the front wheels into the steering wheel. First old tractor I learned on, if you hit a decent rock or hole the “feedback” would about break your wrists, but that system was just two bevel gears that set up a wrestling match between the driver and the front wheels. With the L4701 seems like I get no force from the front wheels back through to the steering wheel. Interesting... And thanks for the explanation.
whitetiger
Nov 20, 2011
3,334
1,751
Kansas City, KS
Correct. All other Kubota tractors including the Grand Ls have hydrostatic steering.
