steering column leak 1992 L3650DT
Teejohnowens
Kubota L3650DT
Jul 18, 2020
Home
NEW MEMBER! i have a 1992 L3650DT that has deveoped a bad hydraulic leak from the top of my steering column under my steering wheel. I have changed the oil seal twice that worked for a while but after a couple of hours on the tractor it starts pouring out again. Any suggestions?
8,755
The L3650 came in 2 different steering control models.
Power steering and hydrostatic steering, which do you have?
Power steering uses mechanical linkage from the steering box to the front wheels.
Hydrostatic steering uses a hydraulic cylinder on the front of the axle to steer it.
Teejohnowens
Kubota L3650DT
Jul 18, 2020
Home
Hydrostatic- singular cylinder in the front
SidecarFlip
Banned
557
The steering column directly connects to a hydraulic controller mounted to the superstructure that supports the dash panel and the steering wheel, sounds like it needs rebuilt.
On my M9 open station (hydrostatic steering) there is a bushing that controls the column slop. I had to replace that and get the controller rebuilt as the sloppy bushing was allowing the controller seal to fail. There should be little to no movement in the column.
On mine, the bushing is hard plastic. Not sure about yours.
Teejohnowens
Kubota L3650DT
Jul 18, 2020
Home
Sorry it took me so long to respond Been busy down here in LA. Thanks for the info.. Does the controller have a kit that I might be able to do are you had to send yours off because something like that wasnt available?
Pau7220
Aug 1, 2017
785
279
Scranton, PA
hey man i see you have the same tractor as i do. Im having abad problem with my steering column leaking under the steering wheel. Have you ever had that problem?
No. I have the old style conventional power steering box under the battery. You have the newer hydrostatic steering with the controller under the steering wheel. You'll need to get some body parts out of the way to find out exactly where it's leaking. If you're lucky it may be a line or a fitting.
NIW can give you some guidance on this unit. He has the same in his tractor.
I believe this is your seal kit.
