Spray Lube
TheMurf
BX1880.with loader and 48 inch deck. 1990 Gravel 12G Riding tractor.
Jun 25, 2022
146
66
Upstate New York
What Spray lubricant do you Gentlemen recommended for using in the linkages and lube points in a BX tractor ? Is chain lube ok ? Or, white litho grease,ok ? I'm surprised there are not more zerk fittings on these machines. Such as the tie rods, steering gear, shift linkage, etc. My old Gravely has fifteen zerk fittings for grease..
4,198
LPS-3 or Woolwax
Pau7220
Aug 1, 2017
785
276
Scranton, PA
LPS-3 or Woolwax
OP asked for a lubricant, aren’t these undercoating / rustproofing?
White lithium makes a mess. The newer clear gel lubes work great. Many companies make them. One example here.
TheMurf
Jun 25, 2022
146
66
Upstate New York
Thank you Gentlemen, I never realized that WD-40 made other formulas..
lynnmor
B2601-1
May 3, 2021
1,322
1,036
Red Lion
Chain lube is fine, some kinds spray on thin and then become thicker when the solvent evaporates allowing it to flow into joints.
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
99
34
Alberta
The problem with spray lube is it gets a lot of lube where you don't want it and not much where you do want it. I prefer an old fashion oil can.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
Krown, but I rarely lube any linkages because I find it just attracts dirt. Over 900 hours and nothing wore out yet.
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
149
68
Waterford, Maine
Deep creep
I have some Deep Creep, and I love it. It is similar to Aero-Kroil, but cost a little less, and will loosen hard stuborn nuts and bolts. I use it sparingly, and use the WD40 for simple stuff, and save the creep for tough jobs.
C1skout
Bx2380
Sep 2, 2022
PA
I've been using ATF from an oil can on linkage joints that are easy to get to, and spray chain lube on the less accessible ones.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
237
85
Jefferson, Ohio
I use it on locks, hinges and anything that moves that does not have a grease fitting.
I also use it on electrical connectors.
nbryan
Jan 3, 2019
1,166
708
Hadashville, Manitoba, Canada
Adding my vote for the Fluid Film. Seeps in and sticks around, smells not bad.
I keep regular WD40 around as well, for dirt/rust penetration and cleaning. Wipe that down and follow with Fluid Film for lasting results.
bmblank
Mar 4, 2015
626
271
Cadillac, MI
I'm glad to see all the votes for Fluidfilm.
Bmyers
May 27, 2019
3,173
3,663
Southern Illinois
I like WD-40 Dry Lube. Doesn't make a mess and so far, I have had good luck with it.
