I haven't herd of to many guys doing much with the super b cabs as far as trying to eliminate the hydro whine. I know guys have taken all the floor panels and under seat panels off on the B3030 and B3000 and put dynamat on the bottom side. I know the superb cab is a lot better then the older ones but it's still to much noise for me. The newer cabs are all one welded unit so not much for plates to remove. My plan...remove the seat. Remove the plastic shrouding from around all the levers on each side of the seat. Remove the rubber floor mat. Now I'm going install dynamat on the fenders, under seat, and under the closed cell foam under the floor mat. Anything that is metal will get dynamat put on. Then anything that is still exposed dynamat after the floor mat is re installed like under the seat and fenders will get 1/2 inch tractor cab insulation put on it. I will update with pictures as I do the project. Not sure when I'll get started but hoping soon. Anyone with any other advice for me would be greatly appreciated.
Sent from my SM-N910V using Tapatalk
