snowblower chute
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
101
Ottawa, ontario
First winter with a front mount blower and as I've done before didn't adjust the skis up high enough. Grab a little too much gravel from the driveway and now the chute is blasted clean, as in no paint left. Not a big deal. When I put it away for the season I'll pressure wash and repaint any needed areas. My question is has anyone lined there chute with Teflon or similar product? Pics if you have them.
bearskinner
Sep 1, 2014
926
241
N. Idaho
I have a similar problem with 1500’ of gravel driveway. The tolerances are too tight to put a liner in the chute. I’ll paint mine also, so it sits all shiny and clean.
thebicman
Feb 2, 2017
337
101
Ottawa, ontario
Going to check out UHMW sheet that is 1/8" thick. Only plan to line the back edge of the chute. Doing my research now and make it a summer mod.
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
There is a thread here, or perhaps TractorByNet on this topic. Can’t link to it, but it was about successfully lining the chute with some type of plastic.
torch
Jun 10, 2016
2,820
1,065
Muskoka, Ont.
"Krazy Karpet" snow toys are a great source of cheap, thin, flexible, slippery snowblower chute lining material.
4,411
Boyz it aint gona stay shiny for ever, use it enjoy it work the snot out of it, and come spring paint what got scuffed up,,, or not
OC455
BX2350 LED ROP, FEL, Belly mower,modified snow blower, pole boom, middle plow
Sep 30, 2016
161
12
Rome NY USA
I painted mine up the best I could.....shiny bare metal now. Just going to paint it back up when the season is over.
7,083
I just give mine a few shots of black or orange paint each year.
Sent from my QTASUN1 using Tapatalk
Pal03
BX25D
Nov 14, 2013
Newfoundland
I will second this used the Krazy Karpet as a liner on my old blower it worked great... just had to make sure the lower edge was fastened well so the snow could not catch the edge and rip it away from the rivets I used to fasten it in place.
