Smallest tractor with hydro "Top n Tilt" ?
miketrock
163
Pa
Can hydro Top n Tilt be put on a B2601 with parts from other kubotas ? Without going completely custom fabbed ? On a B2601, you can get 2 rear remote valves, but Top n Tilt isnt offered.
5,257
1,042
Top and tilt is installed by just plugging into existing rear remotes.
Apart from the "top and tilt" cylinders, hoses, & couplers, nothing else is needed
miketrock
163
Pa
I just went on kubotausa.com and saw that there's a Top n Tilt kit for an L2501 tractor. Can that Top n Tilt kit for the L2501 tractor be used on a B2601 ? Why start from scratch if its already engineered …. maybe just plug n play …?...
MtnViewRanch
866
303
Lakeside Ca.
the L2501 parts will not fit, the B2601 has a totally different 3 point linkage style. there is a fellow on the site that builds kits for your tractor, the fabrication and engineering is second to none.
https://www.fitritehydraulics.com/
Thanks for the compliment. ;)
As mentioned, completely different.
1st pic is for a B series.
2nd pic is for std size L series such as the L2501 that was mentioned, up to an L3901.
Different top link strokes, different ends on both the top & side links.
