Slasher...HELP
Ross82
Kubota 2002dt
Jul 12, 2011
Brisbane, Queensland, Australia
I have recently bought a l2002dt grey market. Been going great no drama's...till today. I took my 4th slasher off to clean it up and upon reattaching it the slasher will not stay up once the tractor is switched off. When the tractor is running there appears to be a hissing sound coming from below the seat but upon inspection I cannot find any leaking hydraulic oil and don't appear to be losing any oil at the gauge. Any help would be greatly appreciated!!!
aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
Welcome to OTT. :)
I don't know what a slasher is. Do you have pics? Can you tell more about the slasher for me to understand what it is?
I'm sure there is good help here for you.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
A little stumped here as well, not real sure what a slasher is. More info and pictures would be great.
pat331
L35, mower, bushhog, cement mixer, grader, boxblade, forks, posthole digger
Mar 31, 2009
298
Ft. Worth, TX
Ross82, I'm guessing a "slasher" is the same as a bushhog over here. But I'm also guessing whatever implement you have on your Kubota will not stay up after you shut off the engine. If that is the case, your problem may be some "O" rings that have failed and need to be replaced. Let us hear from you and some pictures would be helpful. Good Luck!
Kytim
Aug 14, 2009
848
Western Ky
A 4 ft bush hogg, a rough cut mower if you will is what the OP is talking about.
As to why your 3ph wont stay up after removing the mower i currently dont have a clue. sorry.
Ross82
Kubota 2002dt
Jul 12, 2011
Just googled the bushhog and yeah same sort of deal it is a rotary rough cut mower...Slightly different design to what images the search brought up but same deal. Will try to post some pics this weekend if I get a chance. As far as the slasher dropping once the tractor is switched off problem seems to have fixed itself. I took it off and reattached it a few times after my original post and it now stays up fine...don't know why, attached it the same way every time but hey will not complain!! Still have the hissing sound coming from below the seat while the tractor runs though-still can't figure that one out?
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
If the hydraulic is not keeping up your 3ph after you stoped the engine and you hear a 'sound' from below the seat, maybe you have a problem at the valve of your hydraulics. Could be dirt at the oil-side or dirt/damage at the solenoid.
Just a guess...
carl
Kytim
Aug 14, 2009
848
Western Ky
I vote for the "O" rings first. I think there are 2 large ones and maybe 1 smaller one. been a while though.
