I've been looking back on past articles about when to replace a clutch and I'm still a bit lost. The clutch petal on my B6100E seems like it has to go down real far to shift direction or speed. The B6100E has a 6 forward 2 reverse transmission and it's only in 5th gear do I get a little bit of noise and racket coming from it. Also with the 3 speed PTO it can fall into 1st gear on the PTO and it will come on if I'm doing something without the use of the PTO. The tractor seems to pull fine while under a load of grading or snow plowing, she will run up a hill just fine without a problem either. Perhaps maybe I do need to replace the clutch soon or do I need an adjustment? I do have a fair about of slop and free play in the petal before it get close to the point of engagement. By this I mean the petal with flop around some if I'm a bumpy and rough area. So your thoughts, feelings, idea's would be gratefully appreciated!
Eric
Eric
