hoping to find a simplified wiring diagram for my bx 2200 that i could use to get it running. i do not need lights or any thing else like that, just need it to start , run and shut off just need water temp and oil pressure ,volts
My 2002 BX2200 is blowing the 20 amp fuse. While mowing the engine stopped running. I restarted and finished mowing. When I pulled into the shed and turned off the ignition the engine continued to run. I found the 20 amp fuse had blown. Upon replacing it the engine stopped. This has happened...
Be aware that some of the last BX2200s produced have a different wiring scheme, and are actually using the wiring harness and components of the next model, which is I THINK the BX2230.
I believe the presence of an OPC module indicates the later version of the wiring harness/setup being used.
