Shuttle shift lever spring L3600
mosseater
L3600GST
Mar 6, 2016
Dillsburg, PA, USA
Hi, guys! Just bought this tractor and for the life of me, I cant see how this new spring fits in the shuttle shaft lever to keep tension on the lever. I understand it's supposed to keep the lever in the detent notch to make the safety switch but I dont see what the two little 90 degree prongs bent into the spring are supposed to engage. I've flipped it every which way one can and am NOT seeing it. Any help would be appreciated. Thanks!
10,982
Here is a picture of the orientation.
Closed loop side of spring hits handle bracket
Open loop side of spring goes on top of bracket on tube
mosseater
L3600GST
Mar 6, 2016
Dillsburg, PA, USA
Thanks for the drawing. I thought that was right but I was trying to put the bar under the lever, instead of against the shaft where it's supposed to be. Thanks much!
