S Solo3857 New member Equipment M9000 Feb 9, 2022 2 0 1 Georgia Feb 9, 2022 #1 M9000 Has no power to the starting side of the selinoid but does have power to the run side. Therefore it will not start? Any help is appreciated Dan
Henro Well-known member Equipment B2910, BX2200, KX41-2V mini Ex. May 24, 2019 6,074 3,352 113 North of Pittsburgh PA Feb 10, 2022 #2 Check all your fuses? You really need a workshop manual, or at least an electrical diagram... Could be a broken wire...who knows. Probably not the solenoid if you are not getting power to it...
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 35,226 10,435 113 Sandpoint, ID Feb 10, 2022 #3 There is a relay that controls powering the start portion of the fuel solenoid.
