Safety switch, electrical issue, clutch, fuel filter or what? 2003 L3031DT
MWT
2003 L3130DT Woods Finish mower, Land Pride Tiller, LA 723 FEL
Aug 11, 2020
Beebe, AR
Proud owner of a 2003 L3130DT with 1,340 hours. I bought the tractor new. When in gear and working it will begin to shut down. If I depress the clutch it will continue to run. If I put it in neutral it will still idle. Once I put it in gear it may run a few seconds more or 30-45 seconds more and then begin to shut down and finally completely shut down. This the only issue I have ever had with the tractor. Do any of you have any idea what is causing this to happen?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
You may be experiencing a fuel shortage. Algae in the tank is a possibility or even a clogged fuel filter. Pull a line loose and see if you get good steady flow from the tank. Remember to bleed the fuel lines after reconnecting them.
9,298
I'll second the fuel shortage.
algae in the tank and filter will do exactly what your describing.
