Running in 4WD
tsafa
Kubota L3800, FEL, F550 Dump, 10K Trailer
Nov 3, 2013
152
Tobyhanna, PA
Yep! It's one of those things dealers never mention. But very important for any loader work!!!
Nice work!
I don't know why a dealer would withhold such information. They might manage to sell more ballast boxes... which I would have bought had I not had time to think this over on my own and consider other solutions on my own.
The only thing I can think that it might have been hard to sell me on the idea that I needed both to ballast the tires ($500) plus put a ballast box in the back ($500). I might have though he was taking me for a ride had I not handled the tractor without weight in the back.
Bluegill
Jan 11, 2012
1,559
Success Missouri
Most dealers and tractor folks will tell ya loaded tires are all ya need, but they are so wrong! :eek:
The info is in the FEL manual, but seems nobody reads em.
chuck172
L3200, ford4500tlb, ford8n
Feb 12, 2014
38
honesdale, Pa.
I've been reading more and more about ballast and counterweights. I have a brand new L3200 with loaded tires. How much rear counterweight should I shoot for?
Benhameen
Jan 27, 2013
713
136
Southern IL.
If you have the FEL manual there's a section in there about it. I believe it says 600-900lbs and the backhoe attachment weighs 1650lbs, I'm in the process of building mine and it's going to be around 1000lbs. If you have an implement that has any weight to you can use that.
chuck172
Feb 12, 2014
38
honesdale, Pa.
I just looked through the FEL manual, and I can't for the life of me find the counterweight recomendation.
Bluegill
Jan 11, 2012
1,559
Success Missouri
I've experimented with this. No weight on the 3 pt and the tractor sucks at loader work. 400-500 lbs is a huge help. 600-1000 lbs makes this size rig a true work horse, puts the right amount of weight on the rear axle & takes considerable weight off the front axle.
11,121
For your size of tractor like Bluegill says 600-1000 will work great!
rparkinson
297
Northport Maine
I poured a cement block that is 950-1000 lbs. and it works great. Nothing fancy just built a box out of some scrap OSB and shoved a drawbar through it and some plate steel with a hole in it for the top link. tossed some rebar in, some old chokers in it, some scrap metal I had... an old vise that was broken.. works great. What a difference.
Balvar24
L3800 HST, 5ft Rotary Cutter, 5ft Box Blade, Pallet Forks, 72" Rotary Tiller
Feb 18, 2014
56
Rock Ridge
I've found a 6' rototiller is about right for ballast. ;)
1coolbanana
Kubota BX1860
Jan 9, 2014
119
Australia
What would be the weight recommendation for my little L1-22 for loader work?
Im carrying a 400 lb box blade already and the loader is fairly small and only rated at 250 kg (550 lbs?)
Tyres are filled already.
Cheers
11,121
Cheers
Based on the size of your tractor, I would say your about right, my guess would be some where in the 400-600lb range.
Balvar24
Feb 18, 2014
56
Rock Ridge
Had a chance to use that tiller yet?
Yep. Turned a new garden Saturday, then mixed in some horse poop.
Had to go pretty slow on the first pass, but it worked like a champ.
Worked as a balast while scooping the poop!
5,619
OMG I cant even see the ground yet let alone use a tiller,:eek:, if this keeps up Im gona have to plant my taters in some plastic barrels, rebuild the green houses and figure out some way to heat them just to get some lettuce to grow
11,121
My ground is under over a foot of snow! :D
Longmeadow Farm
11
Fonda, New York
I use my 4wd as a chore tractor feeding large round bales and cleaning up around the barns all winter long. It is never out of 4wd, except when I'm moving/hauling large round bales on pavement. The tractor just will not work on ice and snow in 2wd.
11,121
Satuday was dry and 50F out. Sunday we got 1" of ice and about 3" of snow. It's still here.
The difference is I haven't seen ground since November. :eek:
Normal for us, snow hits and that's it till spring! ;)
