Rotary hay cutter .
4,217
Im thinking someone said the rule of thumb is 5hp per foot of equipment
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
It will run a 7' without any problem.
I believe it would handle a 9' but you would need to be carefull on slopes and in thick grass it will probably try to pull the front of your tractor to the right. Alot of people don't like the 9' mowers anyway because they are more prone to break the cutter bar if you run them on ruff ground.
78-79fordman
2013 m7040hd 2013 L3800HST 1969 MF135
May 21, 2013
255
Gillham Ar.
Ya and I missed a good used 7' for $800 . The other day .
Sent from my iPhone 5 using Tapatalk 2
78-79fordman
May 21, 2013
255
Gillham Ar.
Ya I wasn't sure if it was to small or not . And I couldn't just jump in the truck that day to get it . So someone else jumped on it . So it had to been a super deal .
TakerEasy
2010 Kubota M7040 DTC-1
Aug 31, 2010
9
South Texas
I run a JD 275 (Kuhn GMD700) disc mower on the back of my M7040 Cab tractor with no issues at all. Shipping weight is around 1200# but actual weight is around 1050#. It's a 9'2" cut attached mower.
Richard
