I have been making these for a while now, took awhile to get the bugs worked out, had the levels speacial made with the center solid so I could set 3 ball bearings in to take away friction. The hardest part was making sure the hooks hang the same distance from the center and the hooks and chain has to be the same weight. Makes the cutter run alot smother and saves those gear boxes and seals. Any thing that spins need to be balanced, and yes you can take a pair of good scales and do the same, but this takes no batteries.
