ROPS light install BX25D
3,056
Bought the light bar today. Thanks again for all the input.
looking good !
nice "tractor" too - the TWO wheeled one on the left!!!;)
mikeslater
14
US
I just fabricated up a couple of brackets to mount 4 48w led lights two facing forward and the other two to the rear and mounted on the rops on my L3901 ..... trying to figure out how to load a pic of it
Sent from my SM-T530NU using Tapatalk
jgdusc
BX25
May 7, 2013
9
Gilbert SC
Okay attempted install last night. Didn't quite go as expected. No surprise there. Using the diagram I linked originally, maybe you can help. I put the red to the red/blue, the two black off the harness tied together and put to black at rear, the white I capped as I didn't care to have signal light. Turned key and pushed button - no lights. Moved red from harness to red always hot on tractor rear and still nothing.
Do either of the black wires have to ground to the chassis? Maybe I need to hook the white wire to something that will activated the relay?
Also I moved the lights under the ROPS. They are on magnets so they can be moved removed easily. Thoughts on routing the harness? Not sure what to do with all the extra harness that is available. They sure didn't make accessing the rear tap easy. Maybe I should have removed the hoe butt seemed like a lot of work. Thanks!
mikeslater
14
US
You definitely need the black for your ground but I'm not sure what kind of switch your working with
