restoring an old L245DT - tyre issues
jacobhorns
Kubota L245DT
Apr 30, 2013
United kingdom
I am having real trouble in identifying the Bridgestone AG tyres on the front of my Kubota L245DT (4x4) they are the originals. I have managed to buy a nearly new pair that match the back, but i cant find out what model the tyre is, can anyone help?
8,362
The rears are 11.2-24.
ADD: Fronts 7-16
Edit:
OPPS... I could have swore I read rears? :confused: :eek:
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I have a manual and all it says is 7.00-16, 4 ply.
In the pictures the shape of the front tread looks very similar to the rears with the tread bars being tapered from wider at the middle to narrow at the edges, unlike most other R1 tires.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
If you have a loader, you want at least 6-ply rating tires -- preferably 8-ply. If you don't know the brand, virtually any name brand 7x16 R1 tire should be of suitable diameter, and work fine.
olthumpa
L275
May 25, 2011
1,501
Maine
I have a L275DT with 7 x 16 6ply on the front and 12.4 x 24 4ply on the rear, (this is how it came from the dealer new). Hydraulic pressure has been increased and I can lift over 1200lbs with the fel. For me, the 6ply front are doing great.
8,362
MagKarl,
If I'm reading your posts right, you would like to get the tractor back to the "exact" same tires that it originally came with, that's probably not going to happen, and why would you need or want it to be exact? :confused:
Kubota's are not collectable or antique, and your L245 is not going to be worth more with original tires, it might even be worth less. ;)
As far as use, newer style tires and treads offer better wear and traction than old tire designs. ;)
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
MagKarl,
Nope, not me. I was just trying to help the OP by telling him what my manual says.
Mine is a well worn tool and has the looks to prove it.
8,362
Crud, sorry, typo, wrong name associations! :eek:
Jacobhorns, that was for you!:D
