Resetting E-95
S Chamblee
6 foot tiller, land plane, 6 foot bush hog, 2 row hipper
May 10, 2017
22
Mississippi
I’m trying to reset my E-95 warning indicator on the dash of my tractor.. it’s a L4701. Anybody know how to get this done?
200mph
Mar 3, 2017
1,228
65
PA
I found this published, but cannot verify its accuracy.
If you try it, please report back if it works or not. You response might help out others in the future.
Link from where the text below was found: http://www.fixya.com/support/t25743182-turn_error_code_light_off_kubota_l3901
Mode "A" (Test Mode)
1. While holding down both DPF INHIBIT switch and the parked regeneration switch, turn the key switch to "ON" or "START" position.
2. Mode selection display is indicated on the LCD.
3. Press the parked regeneration switch and the mode indicated on the LCD is changed.
4. If "A" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Test mode is selected.
6. If parked regeneration switch is pressed, the display item is changed.
7. Turn off the key switch to finish test mode.
Mode "b" (Error Information Clear Mode)
1. While holding down both DPF INHIBT switch and parked regeneration switch, turn key switch "ON" or "START" position.
3. Press the parked regeneration switch and the mode indication on the LCD is changed.
4. If "b" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Error information Clear mode is selected and the expression "PUSH" is displayed.
6. Press the parked regeneration switch for more than 2 seconds.
7. The expression "OFF" is displayed.
8. Turn off the key switch.
Be sure to clear error information by performing this procedure after servicing is finished.
mdhughes
L3901DT
Dec 10, 2014
1,351
1,106
Ste Geneveive county, MO
For anyone that comes to this post and doesn't know what the error is:
E-95 PTO Solenoid
• PTO solenoid value failure
• Wiring for PTO solenoid is disconnected or short-circuited
• Grounding plate of solenoid is poor contact with chassis
S Chamblee
May 10, 2017
22
Mississippi
The “mode B” instruction reset the computer and fixed the problem, thanks so much!
200mph
Mar 3, 2017
1,228
65
PA
Awesome! Glad it worked and thanks for reporting back to help complete the thread. Future users will appreciate it.
