Removing mower Deck
lugbolt
ZG127S-54
Oct 15, 2015
4,861
1,603
Mid, South, USA
remove belt
remove front hanger
remove both rear pins
raise the deck lift lever
remove deck from under the tractor
installation is exactly opposite
Remote 95
ZD 331 Mower
Jan 15, 2020
31
South, Ga.
Are you referring to the mower Deck belt? If so how is best way to remove or unhook? I get the rest with the pins and such. Thank you for your help and reply.
lugbolt
ZG127S-54
Oct 15, 2015
4,861
1,603
Mid, South, USA
They have two mower belts. One drives the belt and the other goes around all the pulleys on the deck itself.
The drive belt has a tensioner release. It is behind the right rear wheel. Pull it back, then down, then release it. You'll feel the spring tension pulling against you. That will remove most of the tension from the deck drive belt (aka primary belt). Then you just remove the belt.
I'd suggest paying attention to how the tensioner works and which side of the belt the pulley is on.
