I have a Kubota 105s that we use for pulling a batwing bushhog, cutting hay, and raking hay. All of these task require the remote hydraulics to float along the ground. Once you get the remote lever in the float position I can't get it out without tapping on the end of the valve at the end of the remote box. I had this tractor in the dealership to fix this problem, I was told told they removed a "ball" in the remote box and that should fix the problem, but it has not. I've since been told to spray the valve that goes in and out of the box with WD-40 or a lubricant and that should fix the problem. Has anyone else experienced this problem, if so how did you fix? Please advise.
Lonnie B
Lonnie B
