remote hydraulics
Megacab11
M7060 Woods BW12
Nov 4, 2016
Rising Fawn, GA
Just bought a 2016 M7060 had a third remote added with a float option but can't get it to float??? Tried hooking right side, left side, 3 point down, up, middle, the lever will not lock into a float position. Any help?? Thanks. Too, I bought a radio online to install, one for this tractor, will i have to remove the roof to install? thanks.
1970cs
1,124
Grand Ledge
Ok dealer install, they need to make it right! M7611 would be right for a float detent valve for a cab and M7688 for the lever kit. Sounds right on for the numbers so I would have to go with the cable not adjusted properly to lock into detent or the right number wrong part in the box.
Pat
Megacab11
M7060 Woods BW12
Nov 4, 2016
Rising Fawn, GA
Thanks he will i know, just not open till Monday and was hoping to figure it out. Do you know about the radio? Will i have to remove the roof? Thanks again
Megacab11
M7060 Woods BW12
Nov 4, 2016
Rising Fawn, GA
Got radio today and took longer to program than install. Would highly recommend 41239dorinda on ebay if you are looking for a radio for a tractor. Plug/play is a understatement.
BCrouse
196
PA
I had 3 rear remotes installed on my L. One of which being a float valve. When it was first delivered back, the float valve didn't float.
Turns out it was installed incorrectly and wouldn't go into float because of some interference with a hydro line or something.
Dealer sorted it out and it floats just like it should now.
I know L != M, but it might be the same issue?
1970cs
1,124
Grand Ledge
Yes two different birds! L series mount vertically on the lift cover between fender & chassis.
M series are on the very back of the lift cover area stacked horizontally.
Pat
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I took my head liner down as much as I could and removed my radio. It was a real PIA but it worked. May have been easier to take the roof off but I didn't feel like I could do it by myself. If you have a aftermarket radio it will go in much easier, just mount the sleeve and slide the radio in.
