Red fluid?
bywaterdustin2
45
Teulon, Manitoba, Canada
So after cleaning the snow and putting out hay I noticed some red drops on the snow where the tractor went. What is this and where should I start looking for leak? I still have more snow to clear and need to help neibors with chores. Wondering if I need to worry.
Sent from my XP7700 using Tapatalk
CountryBumkin
Sep 27, 2015
568
Central FL
Your tractor is bleeding :D
There are no red fluids from the factory but someone could have used another brand somewhere. I have red grease on my tractor but that would really look like drips in the snow.
Maybe after the snow melts you'll find the rest of that rabbit you ran through the blower. :eek:
mpham
B 2650 cab
Nov 15, 2016
152
Massachusetts
The oils in the tractor should be amber color. I would check the fluid in the radiator after it cools. Should be able to check the level and color in there.
