Rear Wheel Weights
olekid
B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow
Apr 9, 2013
95
Mount Uniacke, Nova Scotia
Greetings, I did a search for rear wheel weights for a B7510 but nothing came up, but that could be me not doing it right. So, I was wandering if you can get a set of rear wheel weights that bolt onto the rims for my "K". If not does anybody have any suggestions? My tires are loaded and I don't want any weight hanging out back on the 3 point hitch. Thanks
FTG-05
L4330 w/FEL, RTV-XG850 and ZD326S
Jul 21, 2013
343
188
TN
Not as pretty as the commercial made steel weights, but I made my own concrete, steel and lead wheel weights for my L4330. I just couldn't see paying +$1/lb for steel/cast iron weights.
One weighs 240 lbs and the other wieghs 260 for a total of 500 lbs added to the rear tires of my tractor.
3,480
Finally got around to getting some pics.
Picked up two 25lb cast iron weights at a local church rummage sale for $1 each.
Cleaned them up, shot some paint on them, then made some mounting hardware.
1st pic shows a "nut" I made with a 1/2"-13 helicoil insert & pressed into the back of the 75lb weight.
2nd shows 1/2"-13 bolt with lock washer, washer, aluminum centering washer, & spacer.
3rd is the weight mounted.
bmwmike
B7100, 1640A loader, tiller, box blade, grader blade, carry all. John deere 455,
Jan 13, 2013
79
clarksville, Tn.
I know this is an old thread , but I thought I would add my home made weight pictures and maybe it would help someone with a new idea.
I took 1/2 inch thick flat bar and made a bracket , welded a grade 8 1 inch bolt in the middle. went to the scrap yard and bought bar bell weights for 22 cents a pound and put 100 pounds per wheel, and since the tires are loaded with liquid this gives me plenty of weight for loader work. I used ( 3) 25 lb weights and (2) 10 lbs weights (used to clear the valve stem) per wheel. This plus the bracket is about 108 lbs.
cost about $30.00 per wheel
mike
I see the pictures did not load so I will try again
3,480
Nice. Clean, simple installation. If your land is as "treed" as mine, you will have to be careful about "collecting" bark. Don't ask how I know. I think I'm keeping the companies that make pruning sealant in business.
5,208
That Sir is one of the best used for bar bell weights I can think of
