Bought my tractor (L4701) at the end of December 2016 and put 70 hrs on it between May and November of 2017. Since then it’s been on my trailer at home until it dries up enough at my property to do more work.
Yesterday I decided to check the air pressure on the tires while doing a little post winter prep to it. Fronts were right on at 34 psi but the rear tires were at 28# psi and 30 psi. Tire specs states 20 psi max pressure so I adjusted them accordingly. You would think the tire guy at the dealership would know how to read and adjust the pressure within spec [emoji23].
Tires:
Firestone SAT II 23 Ags 14.9-24 Tires are not loaded and I know 20 psi is max pressure but what would be considered as low tire pressure? I don’t haul anything real heavy other than my 6ft implements (Cutter, Discs, Land Plane) heaviest is around 900 lbs. I would like to lower them some for maximum traction.
Tires:
