Rear tiller
Frankr1zzo
Bx2350
Sep 16, 2021
Wisconsin
I just picked up a well used bx2350. So the wallet is pretty empty. I was wondering if anyone has taken a bolens shaft drive tiller and converted it to 3 point
3,842
Most important is to check the rotation direction of the Bolens tiller. If the rotation is the same as the Kubota and the tiller you have is designed for the same rotation, I can't see any reason that you can't make his o work.
Lencho
B7100hst
Jan 21, 2017
407
85
NM
Figure out the rpm the tiller is designed for first. I almost bought an old John Deere tiller then learned it was designed for a 2000 rpm rear PTO speed. You should have 540 rpm at your PTO.
