Rear hydraulics - B2410
schmellba99
L3800
Jun 4, 2012
95
Suppose I had an extra hydraulic valve laying around that is collecting dust and thought that it would be nice to potentially implement said valve by installing some rear hydraulic ports to my B2410. Is there a drawing that shows the plumbing routing that I would have to do for this? I have a FEL on it, was thinking that I could plumb it where the valve is used for something like a log splitter or other implement.
3,460
Assuming you have a typical loader valve you can daisy chain a second valve off the power beyond port on the loader valve. The new valve also needs a power beyond circuit and you simply plumb it in series with the loader valve. The tank return port in the new valve also needs to go straight to the sump on the tractor. An easy way to do rhat is by adding a tee into the tank return on the loader valve.
