Rear hydraulic remotes question
mopar2ya
104
ontario canada
I have a L4610 and am putting on a snowblower. Does anyone know the part number for the male end quick disconnect? this is so I can make hoses for the cylinder for the chute on the snowblower. Thanks
jajiu
Jun 5, 2016
454
111
Rowley, Massachusetts
I'm not sure there is a part #, but if it is dealer or factory remotes, they usually are Pioneer type connectors. You can get them at Tractor Supply.
mopar2ya
104
ontario canada
Thanks, I phoned my local Kubota dealer and he said they have different remotes. I was hoping for a Kubota part #. I was thinking they should be standard to all factory installed remotes.
SidecarFlip
Banned
548
All the males will be Pioneer QD's Any farm store will have them and you can buy pre made hoses at TSC as well. Exactly what I did to operate my hay accumulator from my rear remotes.
Remote valves (no the connectors) can be different configurations. Most Kubota's with one rear remote will be detent return to center. Has nothing to do with the couplers at all.
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
The receiver on my dealer installed remote is a Parker break away.
The compatible male implements ends are Pioneer 8010-4 in 1/2 " as MVR noted. Not sure if there is a Kubota #. I just purchased some male ends at a Kubota dealer and they used Pioneer reference #'s. YMMV.
SidecarFlip
Banned
548
Breakaway is standard for safety on powered equipment.Pioneer's break under load manually by pushing in on the male and pulling out. Of course leakage is always present. Keeps the back end greased. Got 6 out back, 6 on the right side and 2 on the loader on each tractor.
