RCB60-I Deck Questions
cmyoch
B8200 4wd and B8200 2wd
Feb 18, 2023
24
Smithton, IL
I decided to mount the mower deck that is original to my uncles' B8200 that he bought new in '84. Not sure how long the deck sat off the machine but I can gather it has not been in service for at least 15-20 years. I replaced the deck belt and blades and serviced the rest of the deck. I mounted it to the tractor last night and plan on a test run with it. I cannot find the manual that came with it so I have a couple questions hopefully someone here can help with.
1. Are the chains on the rear of the deck used to hold it up when not in service?​
2. What are the cut height increments for the guide wheels and rear roller?​
3. Does the deck raise with the 3pt at all?​
I appreciate any input you guys may have for me. PXL_20240303_222648198.jpg PXL_20240628_231635459.jpg PXL_20240628_231656900.jpg
johnjk
Apr 13, 2017
1,795
2,183
West Mansfield, OH
No chains that I’m aware of. Here are the gauge settings for the RC60-24B on my B1700 IMG_2953.jpeg
cmyoch
Feb 18, 2023
24
Smithton, IL
No chains that I’m aware of. Here are the gauge settings for the RC60-24B on my B1700 View attachment 131874
There's a sticker on the left side of the deck that is 99% faded. All I could make out was a Roman Numeral III. I bet that is what this sticker is representing. Initially, I thought it was the deck belt routing diagram but after seeing your picture, I bet it is the deck height adjustment. Thanks!
WAS BANNED FOR NSFW PICS
5,163
I can't help you with mounting, but I can save you from wasting a new belt. Most likely the pulleys have some rust on them. That rust will chew up the new belt. For that reason, I would put the old belt back on and use it to "polish" the pulleys. You can always put the new belt on later if you need it.
cmyoch
Feb 18, 2023
24
Smithton, IL
Good call!
cmyoch
Feb 18, 2023
24
Smithton, IL
Hello guys, I realized that I fell off on this thread and wanted to give an update and closure on my machine. I managed to get the deck properly serviced, cleaned pulleys, new belt, new blades, mounted, and adjusted. My very first cutting with it was a dream. It mowed very smooth and even. I'm very impressed! I will need to replace the worn out guide wheels but other than that, I am thankful for the help you guys have offered.
Once I get the charging system functional and fix the lighting, she is 100% back in action!
