Radiator drain - what tool?
frysl
L3301 LA525 FEL & FDR1672 6' Finish Mower
Jun 13, 2016
96
17
Sumner County, TN
Hello all,I need to drain and flush my radiator, but cannot figure out what to use to remove the drain plug. It’s a plastic plug that looks like it takes an extremely wide and nearly flat Phillips.
I’m afraid that if I use a large flat tip screw driver I’ll crack the plug.
Steve
Jim L.
871
172
A good sized coin will fit the bill. Clamp the coin with a vise-grip if needed. Flat screwdrivers will booger up the plug.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Read post #7 of OF THIS THREAD. It tells you the tool is #3 JIS, which I believe you can get as a screwdriver type or bit by searching the net. I believe JIS stands for Japanese Industrial Standard.
SidecarFlip
Banned
562
Whatever you use, be apprised that the plug is somewhat fragile.
SidecarFlip
Banned
562
Yes. I’m wondering if it wouldn’t be safer removing the lower hose.
Steve
Honestly, that is excatly what I do, I remove the lower hose clamp and wiggle off the hose and drain it that way. Much safer and less hassle.
bird dogger
Vendor Member
Feb 24, 2019
1,741
1,714
North Dakota
When I installed a heater in my home made tractor cab I fabricated this tool for removing that lower radiator plug:
I found a piece of scrap flat steel whose thickness fit the slot on the plug snugly. Cut the steel scrap to size and fit it into a slotted handle of your choice. Or just squeeze it in a pair of vise grips or crescent wrench. Works slick as can be. I thought I better label it so it doesn't get thrown out after years of rolling around in the screwdriver drawer after I forget what its for. :D
Regards,
David
dlundblad
G5200, L2501, ZD1211
May 16, 2009
504
IN
I looked at mine for the first time yesterday and the center looks Pretty foobarred. Anybody know if they are dealer or factory installed?
I would plan on having a spare handy because ive heard theyre tight too.
BX23-S,57 A-C D-14,
5,911
gee, after seeing the plug on the linked post, I'd want the PROPER tool and/or a spare plug before trying to turn the real one !
hmm...will it turn better hot or cold ? I'm thinking cold cause plastic gets 'sticky' when it expands due to heat...but maybe that's a 'good' plastic ?
I can see that head shearing off without a 4 prong, tight fitting tool...having to rip out the remains, cause now it's dribbling and won't seal..oh yeah...ytou started this friday night of a long weekend and NO shops are open until Tuesday......and they'll have to order it...3 days....so a WEEK without your tractor.....:(
SidecarFlip
Banned
562
Removing the lower rad hose is so much easier in my view. I've never taken mine out on either tractor. I looked at it and said to myself, that thing looks like a PITA to remove so I'll do the rad hose, which is what I do.
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
You will remove a lot more of the old fluid by draining it from the radiator hose as well as avoiding the hassle.
SidecarFlip
Banned
562
My owners manual says remove lower hose to drain radiator :D
My view is, why fool with the fragile plug at all. The Rad hose is so much easier but then some people just want to bugger up the plastic plug anyway.....:D:D
AAMeeting
Miami
Be very careful when opening the drain plug as it is very brittle, and if you apply more force than necessary, you will break it. Moreover, it will be quite difficult for you to buy a new plug that fits your radiator. I recommend you go to a professional who has the tools to unscrew the plugs. It is better to pay money to ensure the radiator remains intact. When I needed my drains cleaned, I went to drain cleaning santa ana. I did not regret it, as these guys did a great job in a short time.
