quick attach mounting plates
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
146
59
Central, ME,USA
I need to attach a quick attach mounting plate to my forks. I see the mounting plates (from titan) from 1/4", 5/16", 3/8" and 1/2". I am guessing the difference is what the lift rating will be. I don't want to get to small a thickness and have it bend and let go and I don't want too heavy if I don't need the strength. Does anyone have a rating chart on the different sizes. I have a L6060 with a LA1055 Loader.
Dennis.D
Feb 16, 2018
146
59
Central, ME,USA
Hillbilly77
39
New York
....I don't want too heavy if I don't need the strength.
....I have a L6060 with a LA1055 Loader.
I think it was here that I saw it posted somewhere:
If you get one too weak it'll break. If you get one too strong you'll never know.
Some food for thought:
With your 60HP tractor and a loader with a 1 ton + lift capacity, I doubt a few extra lbs. on the adapter plate will make a difference.
For instance, the Titan cutout plates. The 3/8" only weighs 4lbs. more than the 5/16" plate. The 1/2" plate is only 19lbs. heavier than the 5/16". A negligible amount when you're dealing with a greater than 1 ton capacity.
The solid plates are heavier, but you get the idea. :cool:
mikester
M59 TLB
Oct 21, 2017
3,148
1,626
www.divergentstuff.ca
Do yourself and maybe a loved one a favour and buy a QA set of forks instead of modding yours. If you have to ask these kinds of questions you probably shouldn't be modding lifting devices.
Dennis.D
Feb 16, 2018
146
59
Central, ME,USA
I hate it when someone mentions the obvious. I have been looking at the Titan 4000lb forks and that seems like a pretty good deal and my struggle with how much will it lift is over.
Thanks for all the advise.
