Question about rotary mower and m9000
jtwide
M9000
Nov 20, 2013
Glen St mary, Fl
New member; Guys,
Do you guys think my M9000 can handle a lift-type JD HX-14 rotary mower. The M9000 has a 5000 plus lift rating but the info on tractor data says it can only do 3500 lbs. The mower is about 3000. But that weight is primarily behind the lift measuring point of the tractor and heance a greater load. Only need 50 hp for a pull behind but the one I am looking at is a lift type. Would also put the 1000 pto switch kit in if any buddy has comments about that. Thanks.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Bulldog is the only memeber I'm aware of that has an M9000... hopefully he'll be along shortly to anser.
