Thanks guys Im running 7 and have Norton... Geee I had a Norton Atlas too,,
Yeah I have run the scan and the windows defender as well sucker took like 6 hours to run and found nothing,, Soooo,, Guys thanks much and I do know anything about firefox of any of the others so I guess Im pretty much stuck
Skeets,
You can try to disable things, which may be starting up, via msconfig.
Click on -> Start -> (then type into the search/run box and hit enter) msconfig
you should see the msconfig box (image below) pop up.
Click on the "Startup" TAB near the top of the window
I would suggest disabling anything that is not of the following types:
Microsoft, Norton, Symantec, Google, Intel, HP or Dell or vendor specific, Apple, Adobe, Java/Sun/Oracle, Quicktime, or similar
I would suggest disabling things that have no manufacturer listed in the "Manufacturer" column, or any companies you may not have heard of. YOu can always open this up again and re-enable these if needed.
One caveat is that even if you disable these you may need to also disable the associated "services", but it should catch some of the annoying things that slow Windows down.
HTH
