Pulling the strainer screen on the hydraulic system.
John Tsakiri
BX 25 mid mower
Jul 21, 2011
Bradenton,FL USA
How much oil will come out when you pull the strainer screen on the trans- hydraulic system to clean it without draining the oil. I just want to check and clean it without changing the oil in the tank.
5,647
When you do that make sure you have a 5 gallon container to catch it,,, don't ask how I know this
5,647
Yeppers and by the time I got it,,,,,,,,, I didn't need it no more:mad:
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,475
667
Richmond, Virginia
Dead thread revival.
BX25D
Thinking about doing a screen cleaning in the coming months, to dispose of 'build sparf' that is common. The BH will be off the machine and so will the 3pt.
Has anyone done the shop vac on the dip stick opening so the screen can be pulled minimizing fluid loss?
What diameter is the opening so I can cork it? It would be nice to shut the shop vac off while I slowly work (molasses has nothing on me).
Any thoughts about tilting the tractor to the right? I suspect it will not do anything but it is a passing thought.
11,163
Drain all the fluid before pulling the screen, as others have said if the screen is plugged it's time to change fluid! ;)
William1
Jul 28, 2015
1,475
667
Richmond, Virginia
I'd like to not drain any of the fluid, if possible. Hence my desire to minimize or prevent any from exiting while I have the strainer pulled.
I do not expect the strainer to be plugged, I expect to find metal shavings from the manufacturing process and bits of excess sealant, the stuff I normally see on a strainer the first time.
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
Way I figure it you have two options.
1) Drain the fluid
2) Roll the machine on its side:D
forceten
BX 25d, Grand L6060, Kx040, GL7500, ZD1211 With cab
Sep 4, 2015
281
26
New Jersey
Just so you know, I drained out the fluid to do a change with some fresh UDT2, drained, replaced the filter - went to take the screen out and still more fluid came pouring out. Even after I left the drain plug out for a good 20 mins.
So put something under the screen when you pop it out.
I'm at 50 hours. Screen wasnt bad, but did have some metal shavings on it (always nice to see *shudder*)
Nice and clean now and with the trans fluid swap the HST is a bit quieter
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
Always a good idea, to drill a hole and thread it in such a position, that ALL the oil drains out, before cleaning the screen. Of coures this insight is free, and arrived at after cleaning the screen, the first time...:D:D
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
If you don't want to replace the fluid, I see nothing wrong with draining and refilling with the same fluid. This of course would require you to assure it does not become contaminated with debris in the process. Clean containers and strain before refill should work fine in my opinion.
