The PTO hasn't worked since I bought this tractor. Now I want to add a snow blower and need the PTO. The PTO change lever (#40 in the picture) doesn't really engage the pin (#39) on the shifter fork(#30). From the looks of the diagram I would think that the pin/ball/spring (39/33/34) assembly would "plunge" up & down and would be held in the bottom cup of the lever (40) with the spring tension. My pin/ball/spring (39/33/34)assembly doesn't "plunge" and the lever (40) just touches it but won't engage.
Question #1, Is my assumption correct that the assembly "plunges" up & down? #2, Anybody ever tried to remove, replace, repair the entire fork assembly through the top of the tranny without tearing the whole thing apart? #3, shouldn't the ball be under the spring to engage the detents in the shaft (#35)? #4, What keeps the pin/ball/spring assembly from flying out of the fork? Is it inserted through the bottom of the fork?
Any help will be appreciated,
Tom
Tom
