PTO Jammed due to safety switch? Help!!
smcglon
MX5100
Aug 28, 2013
Pike Road
I have a 2010 MX5100 Kubota. Like an idiot, I got up with the PTO engaged this past (w/6' JD Bush Hog attached) Saturday and the tractor shut down. Turned PTO off and tried to restart and it seems the entire electrical system is half on. A faint buzzing sound is coming from below dash when I turn the key on. When I turn the key once more to start, all lights go out - nothing. Battery is good, wiring is good, checked all fuses (all good), checked safety switch on seat (seems to be good and correctly working). Acts like there needs to be a breaker reset - or something related but I have no idea. Even with the tractor on, the flashers barely turn on. What is even stranger - I can leave it on with the faint buzzing for 30 seconds, turn it off and then turn it back on, all the regular check lights turn on but when I go and turn the ignition once more...nothing and it goes back to the fainting buzz sound. Can't find anything in the manual. Sitting in the middle of my pasture dead. HELP! Thanks, Scott
11,372
Sounds like it could be a dirty/bad battery connection!
Check/remove/clean/reinstall both sides of the battery connections.
How do you know the battery is "good"?
I've seen may a battery over the years that was "good" (measured 12+ volts with meter) and when put under a cranking load they turned out to be bad, they had bad plates or bad internal connections.
hodge
Nov 19, 2010
2,963
531
Love, VA
Cleaning the posts and connectors is free, as well as checking the battery under load, and the charging system (if you get it running).
Have you checked the PTO safety switch?
Welcome to OTT! Hopefully it is something simple.
smcglon
MX5100
Aug 28, 2013
Pike Road
I have checked the battery (full charge) and even jumped off using my F350. After messing with this and posting questions all over, I still can't figure it out but I am convinced it is the PTO that is still engaged. I disconnected the bush hog and can only turn the PTO about a half turn. Also, I have no hydraulics so whatever it is has shut the entire tractor down including the electronics. I jiggled the PTO handle, followed the cable to the transmission and tried to reset there - nothing. Very frustrating on a dumb move. This tractor has been absolutely awesome - perfect running. So, by me getting up off the seat with PTO engaged has triggered something.
11,372
There have been several instances of bad seat and PTO safety switches causing a lot of issues.:( I would check those and all the fuses first.
You won't have any hydraulics if the tractors not running, it's not like they run on electrical power.:rolleyes:
olthumpa
L275
May 25, 2011
1,505
Maine
Not that I'm telling you to do so but if it were mine the seat safety switch would be gone.
The only place these Idiot seat safety switch's belong are in automobiles. When you sit in the drivers seat they kill all cell phones in the vehicle. That would save allot more lives but it might also put some body shops out of business.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Here- this might excite you-
EU plans to fit all cars with speed limiters
All cars could be fitted with devices that stop them going over 70mph, under new EU road safety measures which aim to cut deaths from road accidents by a third.
Under the proposals new cars would be fitted with cameras that could read road speed limit signs and automatically apply the brakes when this is exceeded.
Patrick McLoughlin, the Transport Secretary, is said to be opposed to the plans, which could also mean existing cars are sent to garages to be fitted with the speed limiters, preventing them from going over 70mph.
Read more: http://www.telegraph.co.uk/motoring/...-limiters.html
Life is dangerous and only the smart deserve to survive.
olthumpa
L275
May 25, 2011
1,505
Maine
Allot of vehicles already have speed limiters in them in the USA.
Stupidity trumps smart. A little over a year ago four teenage girls were texting each other in the same car. They got onto the interstate going in the wrong direction ,(going North in the South bound lane). They met another vehicle that had five people in it head on. All four girls were killed instantly. The five in the other vehicle were life long friends, four died and the other will never be the same physically or mentally.
m32825
L3800HST
Jul 12, 2013
227
44
Central FL
The PTO selector has to be in the disengaged position (back) in order to start the engine. Is it possible that with all the excitement, you've still got it in the engaged position? Hoping it's something simple!
-- Carl
