I bought a new M5140 and LP 6' cutter.
I can not get the PTO U-Joint to slide all the way home. It will slide as far as the retaining balls and that's it. I push the ring forward to release the balls but it still refuses to go home. I called the dealer and he said "It's just new and will loosen up in time"
When I received the tractor, the cutter was mounted...(I don't know how they were able to slide the U-Joint on) When I went to dismount the cutter, I could not get the U-Joint to slide off. Finally, I took a "come-a-long" and pulled it off.
I called Land Pride about the problem, and the rep said "I understand your frustration, sometimes those can be a problem" (That really didn't help!)
I really don't believe this should be such a problem! This is not "rocket science" But I noticed a sticker "made in China" Maybe these shafts are for China tractors?
