[solved] problem with electrovalve
Hi, today i was investigating my tractor problem (on hydraulic lifting) and i enabled manually the lift movement (pushing in the front of the eV). I noticed IT was hard to pull but i thought it was so because i didn't use it from month.
When i released the screwdriver i used ti pull the ev stucked enabled. I tried to softly hit it but with no results. I removed the coil and hitted again but nothing happened (when i start the motor the movement try to lift eventi without coil).
Is there a way to fix it or must i look for spare parts? Where can i find it? (I have a bulltra b1 14)
Thanks
Thanks
