Problem starting L2900
GCTucson
L2900GST
May 24, 2018
15
Tucson
Hi all,
I'm having issues starting my L2900 GST even though it's got a brand new battery.
When I turn the key, there is a click and the display lights come on, but no starter action. Of course it's in neutral with brake on and out of gear.
If I push in the clutch a few times, shift back and forth between forward and reverse and keep turning the key, it will eventually start and run perfectly. But if I turn it off, I have the same problem again, whether the tractor is hot or cold.
Is there some kind of sender that could be going bad?
Thanks!
10,673
Sounds like you have an issue with the OPC module.
It's the module that all the safety inputs go to and then passes on the starter signal.
N3BP
Sep 20, 2016
510
239
Lebanon, PA
Mine does the same thing. I've traced it back to one of the neutral safety switches for the shuttle shifter. I have to wiggle it when starting. At some point I plan to bypass it.....
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
A bad ground connection can also cause starting problems.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
Since pushing the clutch several times and going between gears seems to "fix" the problem I'd start with those switches.
GCTucson
L2900GST
May 24, 2018
15
Tucson
Would replacing an OPC module be a DIY job or will I need to get a Kubota tech out here?
Thanks!
GCTucson
L2900GST
May 24, 2018
15
Tucson
Thanks for your replies.
I'll pull the tractor out and see if I can trace back to the problem switches. Is an OPC module a DIY fix or will I need to get a Kubota tech to do that?
Thanks again.
N3BP
Sep 20, 2016
510
239
Lebanon, PA
Intermittent electrical issues are normally switch related. The contacts get tarnished and lose their ability to conduct. If it's related to the module, it's most likely a plug that is loose or has a bad connection. If I had an electrical diagram of the L2900, I could help you out better, but unfortunately I do not.
5,255
1,055
Thanks again.
See attached photo of OPC. A plug in type connection easily done.
However, before deciding the OPC is faulty you need to rule out all the safety switches that feed it info.
I have attached some OPC info but for a different model tractor. This will give you a better understanding of the OPC system on any tractor.
Palmettokat
M6800, B2710, L6060, Volvo 5 ton excavator and implements.
Apr 21, 2020
251
53
South Carolina
It could also be an issue with battery cables, clean the clamps on the post and also the ends where they bolt to the frame and the solenoid. As to the clutch and gear shift, hold the key in the start position and move one at the time and see if it starts. Could be you have a safety switch that is slightly out of adjust or loose or bad.
Sjess12
14
Potsdam ny
A little trick I've learned more than once. Hold the key all the way to the right as you would to crank the tractor over. If it doesn't start keep holding the key there and wiggle each safety switch at a time. Such as hold the key to start and wiggle PTO engage lever etc. Etc.
