Preventing hydraulic rust
jrdjhnson
L3560-LE
Mar 12, 2022
Hi! I have a BH92 in a fairly humid environment that will see infrequent use. I was hoping for some details on keeping the hydraulic rams rust free... I can see in the manual and on this forum that coating the rams in grease is one way to do this. Do I just slather the exposed portions of the cylinders in grease? Any particular grease? Does it get wiped off before the next use? Do I have to worry about any residual grease getting past the seal and contaminating the hydraulic oil? Should I "clean" the rams after greasing, or will just a cloth wipe-off work?
7,147
If you really want to, spray something like WD40 on them. I've got cylinders that are 40/50 years old, never protected and never rusted.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
852
774
E.
same situation here as I store in pole shed with dirt floor.
I store hoe with hydro shafts retracted keeps majority non exposed and rust free.
can of PB blaster silicone is what I use on exposed surfaces and never had a problem. And I do not clean before use.
3,685
The rams are hardened chrome and will not rust. Coating them with grease will attract dirt and grit and will likely damage the oil and dust seals and create leaks. Wipe them with a clean rag lightly sprayed with WD40 is all I’d ever do.
5,889
retract the rams for sure !
if exposed to rain condensation, spray with a 'rust check' spray or thick oil, then lightly cover with a 'hat'. Some kind of waterproof cover that will keep water from 'pooling' on the seals/ends of the cylinders BUT allow air to get there.
jrdjhnson
L3560-LE
Mar 12, 2022
All very helpful responses, thank you! The manual just states to grease the cylinders, without any additional detail, so the comments here are helpful to understand how things play out in the wild. Obviously would love to store it with the cylinders retracted, but just not practical with my current storage and such a big hoe. I'll look into all the suggestions here.
MapleLeafFarmer
Dec 2, 2019
852
774
E.
btw. welcome to OTT and good on you for asking such a great question.
It is very expensive to replace / rebuild cyl. so being proactive is well worth it. A little care and attention and a BH 92 will give you lots of years of great service
Seals can generally handle significant amounts of common dirt / sand / etc... from regular use but rust over the seals is a killer.
Finding a way to retract if at all possible strongly recommended.
lynnmor
B2601-1
May 3, 2021
1,687
1,475
Red Lion
If the equipment is operated near a corrosive environment like road salt or salt water, I would use a product made to be a corrosion inhibitor. Long term storage demands protection as well. I use Rust-Lick spray on surfaces I want to protect. WD-40 is about as close to nothing as you can get.
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
168
76
Danville
Look to a marine corrosion protector in spray form. I have a few cans of Pennzoil marine protectant but it seems that is no longer available. These products are great at corrosion protection without building a film on the hydraulics.
Mark_BX25D
Bx25D
Jul 19, 2020
1,948
1,452
Exactly. I saw a widowed friend of ours ruin her log splitter by leaving it extended, and it rusted. Yes, chrome steel WILL rust.
I like Fluid Film. Great for a lot of things.
5,185
WD-40 is consumer junk that evaporates while you look at it!
Use a good quality silicone spray, or for even better protection use LPS-3.
LPS-3 is somewhat thicker, (good stuff) and actually has a MIl. spec.
It will provide rust protection for months!
It is available in spray cans or a trigger spray bottle.
I keep everything I own inside, but if I stored outside, I would use LPS-3 on any metal surface not painted.
5,889
consider building a shed for it, open on 2 sides ,at least 1 foot taller than BH. Allows for good airflow, keeps sun off, reduces condensation problems. For sure 'oil down' the WHOLE unit when warm and dry, before storing.
7,147
Partner, WD40 is a water dispersant and it was the 40 formulation that provided the protection needed for the aerospace industry. It gets a bad rap because folks thinks it's a lubricant and use it for other than it's intended use. If used to spray on saw blades, cylinder rams and other bare metal things moisture gets on, rust will be reduced/eliminated.
5,185
WD-40 is a LIGHTWEIGHT water dispersant, with very poor protective/exposure longevity!
WD-40 DOES NOT HAVE A MIL. SPEC.
What does Mil Spec. mean?
Approved for military use.
WD-40 is NOT approved for military use!
That rating, or lack thereof, provides a most obvious impartial review!
5,185
Chanceywd
Mar 26, 2021
746
693
central ny
I don't use nor have I bought WD-40 in the last 50 years. Fluid film or as you say LPS.
I knew someone who would use WD-40 on his firearms and wouldn't listen.
