Pressure on Hydraulic lines
kcs
Kubota B2650
Jan 9, 2021
148
I keep my LP grappler in a shed. But it gets pretty hot in there. Last time when I went to connect the hydraulic lines. It had some much pressure I couldn’t connect. Is there any way to relieve the pressure other than pushing on the when I go to connect with a piece of wood or a screw driver
ferguson
L3130
Jan 19, 2022
321
125
w.v.
Have a L3130 Also have a grapple sits outside. Just don't think temp change 50 or 60 degrees expandes the oil that much. Maby the grapple was not all the way closed when you removed it. This will put psi on one of lines. I have done this. I use a 1/4" punch rag & tap the pin in to relive psi. The flat face on a punch will not damage the pin a screwdriver will work but harder to keep on the pin. my 2 cents
5,713
The oil cannot expand so thats not how it works in the case ov a gas the Ideal Gas law defines the relationship:
PV =nRT
So what is the relationship for a petroleum oil. Interesting question and Google returned a very unteresting P v T answer. Next time it happens might be educational to test the.effect of a couple ice packs applied to the cylinders. Or for a more immediate result couple the hoses together with a pressure gauge in the middle and apply a heat gun to the cylinders. Looks like a small delta T produces a big change.
Pressure-temperature-relationship-of-the-hydraulic-fluid-inside-the-pressure-vessel.png
5,228
The male poppet type, you can whack it with a hardwood block/mallet to relieve pressure. A brass punch also works. Females are a bit harder to deal with (shocking, I know). You can unscrew the fitting a bit to relieve pressure but arguably not ideal SOP.
There are a variety of tools designed to assist with the issue. Example:https://www.amazon.com/Original-Hydraulic-Coupling-Pressure-Decompression/dp/B0BRTB5W4B
I don’t have any sort of decompression tool so not making a recommendation, just pointing out there are a variety of options.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
824
728
E.
fwiw: over the decades I have become accustomed to whenever I take a hydraulic piece of equipment off, on the impliment side I give the poppet of both the male and female end a quick push in.
A small amount fluid bleeds into the rag.
Bleeding off a little fluid each time I change an implement (fingers stay crossed) seems to keep almost all my connection problems away.
I also cycle the tractor controls with acc. on but engine off prior to hooking stuff up to bleed off pressure from tractor side. Sometimes I even give the poppets a push in before facing the implement.
I keep small wooden dowls scatted around my shops for making this work.
mikester
M59 TLB
Oct 21, 2017
3,932
2,580
www.divergentstuff.ca
I'll put a clean rag to cover the end before tapping with a mallet. Stops oil spray.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
You could buy a set of couplers to connect to your grapple when it is parked, and just leave the open ends in a pail with a cover. That way any oil pressure would just drain into the pail.
3,031
1,147
Take and change the couplers on your grapple and tractor so that each has a male end and a female end. That way when you take off the grapple you can couple the hoses together. If coupled together then they equalize the oil in the hoses as temperature changes and will be easy to hook up.
lynnmor
B2601-1
May 3, 2021
1,659
1,435
Red Lion
If you do that, leave the grapple in a middle position, if it is at the end of travel pressure can still build as it tries to force the immovable cylinder.
SDT
multiple and various
Apr 15, 2018
3,320
1,102
SE, IN
Best (not least expensive) solution is a set of flat-faced couplers.
lgeist04
MX6000 HSTC, LP RCF2060, LP SGC1060, Woodland Mills WG24, Titan forks.
Jan 2, 2020
20
Soldier ks
Leave the grapple all the way open when you disconnect the hoses. Then connect the hoses together allowing the grapple to close and the fluid in the lines to drain into the grapple cylinders. I have not had issues since I started doing this.
kcs
Kubota B2650
Jan 9, 2021
148
Awesome thanks for all the help. I will try connecting the ends together. Also like the idea of putting extra connectors and letting it drain into a pail.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
268
Jefferson, Ohio
I soon as I unhook the attachment I hook this up. There is air in the black pipe. Once in a while I open the ball valve to let the oil out.
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
Older tractor equipment used agricultural type quick connectors. Not as easy to keep clean but easier to decompress. Gear tractors very tolerant hydraulic contamination. Construction equipment lead the flatface type QD, easy to wipe clean and better for hydraulic drive transmission. Also compliant to fluid loss on construction sites.
Most of my equipment is now converted to flatface QDs. Techniques described help connecting 95% of the time. I’m not as big of a gorilla as I once was so tools help too. Homemade or store bought.
5,713
The single biggest advantage of flat face couplers and the reason they are used on construction equipment is flow rate. A 1/2 body flst face coupler can handle twice the flow of an agricultural coupler and with less pressure drop.
If you don't need high flow you are not getting much for the substantial price premium.
