pneumatic grease gun not pushing grease, front bucket pin problem
joesmith123
L295DT, BX1500
Mar 18, 2023
282
19
earth
You really need to disassemble the whole unit,clean, dry, lightly oil ,then 'rustcheck' or other 'light' grease.
There's a $10 'sleeve' in the base of the handle that needs oiling as your grease won't get in there.
There's also 2 bearings in the 'tube' behind the gold bolt, all that 'cavity' needs oiling as well.
Yes this is the task I will be doing next chance I get
the machine needed greased very much -
Before greasing: the forward and reverse pedal was taking a toll on me, wearing me out with how hard I needed to push
Yesterday while greasing: one of the most dry areas was the grease fitting on the pedal
After greasing: machine glides smoothly, less effort to push that pedal
I found myself having do it by hand sometimes because it was so hard to push
The machine can barely move any earth, then I was having to stop every little bit to put new pin, etc
I love when a machine is fully functional and no hindrances
Poor little machine and the beating I have put it, I am amazed what it has done and is still going
3,845
If that machine was an animal you would be residing in the local jail awaiting your trial for abuse.
joesmith123
L295DT, BX1500
Mar 18, 2023
282
19
earth
It is for a good cause, sacrifice the little girl to fix her mother, the 295DT, excited is an understatement
Finally soon, major surgery happening, gonna park 2 broken l295dts next to each other, and make one work
I am so excited to get into that old Japanese diesel, bring her back to life
The one with less hours has a whole in the side of the block
Once I park them next to each other on level dirt but sheltered from rain, I post photos and get the proper advice
I am so close to having that spot flat and ready for the big surgery
