Picked up a nail in the rear - DIY Plug or take it in?
LarryBud
L3130
Dec 5, 2020
249
129
Cleveland, MO
I have a L3130. I was mowing over by the neighbors and evidently, they tossed a small piece of 2x4 with a framing nail punched through and pointing up. My rear picked it up and when I removed it, the air gushed out.
Now, I see some use a plug to fix it and others say have it patched. What's the best route for a permanent fix?
6,792
No fluid in the tire?
Given it will never exceed 60 mph, I suggest you use whichever you prefer.
While I’ve had auto tires plugged, it’s not something I like for concern of failure. That’s never happened either.
LarryBud
L3130
Dec 5, 2020
249
129
Cleveland, MO
No fluid. Just air.
Edke6bnl
B7800 Kubota, case 1840 Skidsteer Ford 3500
Mar 31, 2022
260
142
Agua Dulce, California
I just picked up a oldet kubota neglected for over 6 years, there are many plugs in several tires and holds air after sitting fir years
3,195
Try it yourself. What can you lose? If it doesn't work for you, you can still take the tire to a pro.
Probably will work for you though... :)
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
My first tractor had the same misfortune with meeting up with a nail. I plugged it, kept it for 10 more years putting on about 600 more hours with no issues.
Note to self - when moving into newly constructed house just assume the carpenters didn't give crap where they threw their scrap.
Pawnee
L2501
Jul 1, 2021
356
321
Ontario Canada
DIY tire repair is a hot topic on motorcycle forums. A plug failure could spell disaster in that situation yet about 80% of the guys do it without consequence. The other 20% think those guys are nuts.
On a slow moving tractor there is far less risk.
Plug it, check it a couple times ,and keep on truckin'.
torch
Jun 10, 2016
2,707
937
Muskoka, Ont.
If you can remove the tire, use a mushroom plug from the inside. Kind of a cross between a patch and a plug. Can't blow out. Even approved by motorcycle tire manufacturers (although they do derate the speed rating if you install one.)
Captain13
Feb 27, 2019
519
170
Kathleen, GA
i still keep a plug kit on my bike just to get me to a place where I can get a permanent repair or a new tire. Most places won’t even patch a motorcycle tire at all.
Edke6bnl
Mar 31, 2022
260
142
For cars and motorcycles this is the best choice, because this will reduce the chances to rusting out the steel cords
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
222
236
Pennsylvania
I use both...a plug and, green slime. Like preventive medicine.Less to worry about.
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
I've put many highway miles on car or truck with plugs. I have never had a failure, and don't expect to. As far as I'm concerned, a plug IS a permanent fix. You'll wear out a tire before that plug will fail.
As long as it's in the tread, and not the sidewall, you are good.
And if it fails, well, then you can worry about a patch.
There's ONE caveat - if you are going to run with unusually low pressure for some reason, a plug will probably fail before a patch will.
Other than that, it's a difference that makes no difference.
MOOTS
MX6000
Jun 27, 2019
2,144
2,637
Canton, Georgia
Plug it and forget about it.
Our JD110 loader at work has many, many plugs in its tires, some holes have up to 3 plugs.
3,388
Off road/Ag use..?? plug it. Good for 20-30 years.
ON hwy use? Repair it via patch or tire-shop.
torch
Jun 10, 2016
2,707
937
Muskoka, Ont.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
448
238
Randolph county N.C.
Plugged several tractor, zero turn, ATV, RTVX tires and the all sealed up fine and ran the tires for several more seasons. Low speed off road use I think it is safe.
SonofOrange
L245F with 1200 loader, T1870, AT70, GL-5500(S)
Sep 1, 2021
101
Monroe, GA
I've always understood that the patch is preferred over plugs and slime due to balancing considerations. Maybe I'm misinformed. Either way, I've got several plugs in my slow moving equipment and highway tires. The only problems I've had is when I've tried to plug a hole that was too large. Just so you know, a hole from a gutter spike is too big to plug.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,427
1,714
Kalamazoo, MI
Pluggit. My favorite tire killer is a carbide tipped stud from a snow machine track. That monker will deflate a tire in 2 miles.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
There is no need to remove the tire from the wheel. .. these are low speed off road tires. Use a standard string repair, available with tools and glue for $10 or so. About 2 years ago I stuffed about six or eight 8” into my RR R-4 crown area when I picked up a pin from a sliding barn door roller. Still holding, calcium filled.
