Phoenix Tiller stopped working.
nkcfd148
Kubota L4400 B1750
Aug 6, 2026
Platte City
Hello everyone,
A novice when it comes to tractors and implements. Have a Phoenix (Sicma) T4-40 tiller currently attached to my B1750. After doing some garden work. Started to till and smooth sons motocross track. Only 1-2 inches deep. Then all of a sudden there was a slight grinding noise so I shut it down. After further investigation, noticed the PTO would spin but the tiller would only engage for a couple seconds. Checked gear fluid levels and adjusted slip clutch. No changes. What would be the next plan of attack? Can’t find any videos specific to my problem. Pretty sure the chain is still ok based on how outs acting. Have a video but can’t get it to load. Thanks in advance for any info.
6,647
Check the chain. Make sure it’s properly tensioned. If you’re not sure what “properly tensioned” is, review the manual for the tiller. It should have a procedure for setting tension.
Check the sprockets. Make sure they all have all their teeth.
Edit: And when you say the PTO spins, assume that means it’s spinning on the tiller end, not just the tractor end.
nkcfd148
Kubota L4400 B1750
Aug 6, 2026
Platte City
Sprocket was next on my list. Was just getting other opinions before tearing into it.
The tractor PTO/Eurocardan is what spins. Tiller stops after a bit.
bird dogger
Feb 24, 2019
1,793
1,766
North Dakota
Could it be as simple as a shear bolt connecting the slip clutch to the tiller gear box shaft has sheared off?
I had to track down a malfunction on my old Howard tiller. Oddly enough, it turned out that poor welds connecting the chain drive gear to the main tiller shaft had let loose. Everything was spinning as it should except for that shaft. Odd things do happen.
nkcfd148
Kubota L4400 B1750
Aug 6, 2026
Platte City
I will double check again. Everything looked intact when I inspected and adjusted the slip clutch. One of the first things I checked.
nkcfd148
Kubota L4400 B1750
Aug 6, 2026
Platte City
Don’t have a manual, but looked up and saved one online. Didn’t give specifics on what the tension should be. I’ll keep looking though. Thanks.
bird dogger
Feb 24, 2019
1,793
1,766
North Dakota
When you take off the end housing cover (whether its oil bath or grease inside) you'll be able to see what's turning and what's not when the pto is engaged and the main shaft is stationary.
